That's right Daniele.
SPS Motorsport
01-11-2019, 15:53
04-11-2019, 21:55
05-11-2019, 11:03
Congratulations on your results!
Too bad for the nd but I guess it's racing... Nothing you can't fix I see BTW! Inviato dal mio LG-H870 utilizzando Tapatalk
Mx5 NB Honda K20 Turbo
EX -- Alfa 75 2.0 Twin Spark 1987 Alfa Giulietta 2.0 1985 EX -- Alfa 166 V6 3.2 24v 2003
05-11-2019, 11:09
Thank You very much.
![]() Yes, the damage is not too big, so we will fix it soon without any problems.
19-11-2019, 17:14
Long time nothing new here. So there You get a cool customer project.
![]() This 1.6L Miata import got a turbo conversion and has still its air conditioning installed and running. The engine got forged parts and the turbo is an upgraded TD04 turbocharger. Now the engine produces 281hp at the flywheel and 362Nm/267lbft torque. The specs: - 1.6L B6 engine bored to 79mm - JE pistons 79mm - Cometic head gasket 79mm - Molnar Technologies conrods - ACL main bearings - King conrod bearings - Upgrade TD04 turbocharger - SPS 700ccm fuel injectors - SPS engine oil cooling kit - Competition Clutch Stage 3 - BC Racing BR-series coilover - Fender Flares - Japan Racing JR19 8Jx15 0mm offset with 20mm spacers front and 25mm spacers rear - Nankang NS-2R 195/50 R15 tires ![]() ![]() ![]() ![]() ![]() ![]() ![]() Best regards Guido from SPS
02-12-2019, 16:33
(Questo messaggio è stato modificato l'ultima volta il: 02-12-2019, 16:47 da Guido@SPS.)
Here we have one of a rarer conversion, a rotrex C15-60 supercharger. The 1.8L BP engine produces 200 hp with 242 Nm/178 lbft torque. It also has a Stoptech Big Brake Kit, some 15" Rota Grid wheels with Federal 595 RS-R tires in 205/50 ZR15, a SPS "Extreme" rollbar, a race header, a mishimoto radiator and our coilover setup.
13-12-2019, 18:20
Here You can see a really serious project.
This NC is getting a Borg Warner EFR7163 turbocharger on a forged engine running with 1.3 bar boost tuned with a MS3. It will produce around 400hp at the flywheel with 455Nm/336lbft torque. It also gets a full roll cage, fender flares, gearbox oil cooling system and differential oil cooling system. ![]() ![]() ![]() ![]() ![]() ![]() Best regards Guido from SPS
13-12-2019, 22:12
« Precedente | Successivo »
