					SPS Motorsport
		04-10-2019, 11:00
			This swap with the parts we used including work and tuning is something about 15.000€.
	Best regards Guido from SPS
		04-10-2019, 12:38
			Hello Fletch,
	yes this is possible. We approved this V6 KL swap with TUV and a V6 swap with a Jaguar 3.0L V6. You may know this as the "Rocketeer" Kit. Both cars are streetlegal now. YouTube: https://youtu.be/NLP29fX_EHc Best regards Guido from SPS
		07-10-2019, 14:09
			This 10th-anniversary NB got in our workshop because on our last trackday in Anneau Du Rhin the timing belt got destroyed by some dirt of the track.
	We supposed the valves also got broken because of other camshafts and higher compression, but luckily nothing else got broken. It is a 1.8L bored to 2.0L with an ITB and very aggressive camshafts. On the dyno it produces 230 natural aspirated horsepower at 7800rpm. Because of that power and a shorter final drive in combination with a 6-speed gearbox and a shortshifter it is really much fun to drive. ![]() Specs: - 1.8L BP bored to 2.0L with 85.5mm pistons - Jenvey ITB - Mishimoto X-Line radiator for Honda Civic - Reverie RH carbon airbox with custom ram-air hose - König K 5000 seats - OZ Ultraleggera 15 inch ![]() ![]() ![]() ![]() ![]() Best regards Guido from SPS
		09-10-2019, 12:22
			This is a really nice sleeper setup. A 1.8L NA with a GT3071R turbocharger producing more than 350hp.
	The owner doesn't want a rollover bar because he wants to keep the sleeper look. Specs: - 1.8L BP bored for 84.5mm Wiseco pistons - K1 conrods - ACL main- and rod bearings - Boundary stage 2 oilpump - ARP head stud kit - Garret GT3071R turbocharger - ATI Superdamper - SPS oil cooling kit - Mishimoto radiator - Skid Nation reroute kit - 6-speed gearbox - MiataRoadster short shifter - StopTech BBK 280mm - Rota Strike 8x15 20mm offset with Nankang AR-1 - CanChecked Display universal 2.8" ![]() ![]() ![]() ![]() ![]() YouTube: https://youtu.be/DX4rvrRTUKQ Best regards Guido from SPS
		23-10-2019, 12:04
			This is a supercharged NC from a good friend of the company. The car got a Rotrex C30/94 on its 2.0L installed producing 303hp and 314Nm.
	Also the car got a nice look with it shiny rims and low coilover setup. I think Kermit likes that. ![]() ![]() ![]() ![]() ![]() ![]() ![]() YouTube: https://youtu.be/24y9trimIPU Instagram: https://www.instagram.com/ndi.like Best regards Guido from SPS
		25-10-2019, 18:55
			Sps
![]() Inviato dal mio iPhone utilizzando Tapatalk
- NC 2.0
	-SAPONETTA KILLER cit. A.Ticchi -midified engine by Lazzeri -camme mondiale R -volano oem alleggerito -AEM intake -collettori 4-1 scat I.L. -terminale cobalt -re-map ECU Mondiale R -engine torque damper -grams performance 70mm throttle body -singular motosports hood louvers -Öhlins Road&Track DFV coilover -corner balancing -sway bars rx8 gialle -end links regolabili I.L. -full powerflex -full tubi in treccia Mondiale R -dischi ant e post campana Mondiale R -wilwood 4 pot calipper -awr brake dukt -nankang ar1 235/40/17 -wedssport tc105x 17x9 -Full Alluminium struct braces kit I.L. -rev.limiter gauges -carbonmiata rear splitter -MX-5passion io c'ero!!! SOTTO 5000 NON è AMORE!!!
		01-11-2019, 13:41
(Questo messaggio è stato modificato l'ultima volta il: 01-11-2019, 14:17 da Guido@SPS.)
			Hey guys,
	this is our second MX-5 ND. It is wrapped in british racing green and has some cool stuff installed. It is also our first car with a 200hp package with a full exhaust system including race header and software tuning. It has also following parts installed: - SPS circuit coilover - StopTech 280mm 4-pistons Big Brake Kit - Rays TE37 rims 8x16 25mm offset with Toyo R888 205/50 R16 tires - Friedrich Motorsport exhaust system - BBR GTi race header - Recaro Pole Position seats - CAE short shifter ![]() ![]() ![]() ![]() ![]() ![]() ![]() YouTube: https://youtu.be/pgN2g_6ycn8 Best regards Guido from SPS  |
					« Precedente | Successivo »
![[Immagine: hl8zbm7t.jpg]](https://s17.directupload.net/images/191007/temp/hl8zbm7t.jpg)
![[Immagine: qun9q4vb.jpg]](https://s17.directupload.net/images/191007/temp/qun9q4vb.jpg)
![[Immagine: mcalaqve.jpg]](https://s17.directupload.net/images/191007/temp/mcalaqve.jpg)
![[Immagine: azc9skjm.jpg]](https://s17.directupload.net/images/191007/temp/azc9skjm.jpg)
![[Immagine: 4cy6dee2.jpg]](https://s17.directupload.net/images/191007/temp/4cy6dee2.jpg)
![[Immagine: 9832is9c.jpg]](https://s17.directupload.net/images/191009/temp/9832is9c.jpg)
![[Immagine: y759emkf.jpg]](https://s17.directupload.net/images/191009/temp/y759emkf.jpg)
![[Immagine: 3zqmk2yd.jpg]](https://s17.directupload.net/images/191009/temp/3zqmk2yd.jpg)
![[Immagine: zmeq96h2.jpg]](https://s17.directupload.net/images/191009/temp/zmeq96h2.jpg)
![[Immagine: mjd5cqgb.jpg]](https://s17.directupload.net/images/191009/temp/mjd5cqgb.jpg)
![[Immagine: ryte9twx.jpg]](https://s17.directupload.net/images/191023/temp/ryte9twx.jpg)
![[Immagine: vsimdxas.jpg]](https://s17.directupload.net/images/191023/temp/vsimdxas.jpg)
![[Immagine: t93ity2b.jpg]](https://s17.directupload.net/images/191023/temp/t93ity2b.jpg)
![[Immagine: 3fnrttf4.jpg]](https://s17.directupload.net/images/191023/temp/3fnrttf4.jpg)
![[Immagine: rzyhbn9s.jpg]](https://s17.directupload.net/images/191023/temp/rzyhbn9s.jpg)
![[Immagine: cofebgu5.jpg]](https://s17.directupload.net/images/191023/temp/cofebgu5.jpg)
![[Immagine: qizaef9h.jpg]](https://s19.directupload.net/images/191101/temp/qizaef9h.jpg)
![[Immagine: 4rmdantw.jpg]](https://s19.directupload.net/images/191101/temp/4rmdantw.jpg)
![[Immagine: syxjj6fa.jpg]](https://s19.directupload.net/images/191101/temp/syxjj6fa.jpg)
![[Immagine: o42r5pr3.jpg]](https://s19.directupload.net/images/191101/temp/o42r5pr3.jpg)
![[Immagine: 76nfck7c.jpg]](https://s19.directupload.net/images/191101/temp/76nfck7c.jpg)
![[Immagine: dcumihc7.jpg]](https://s19.directupload.net/images/191101/temp/dcumihc7.jpg)
![[Immagine: dxy8spji.jpg]](https://s19.directupload.net/images/191101/temp/dxy8spji.jpg)
