[ND] Aggiornamento Mzd Connect / inserimento mods - Versione stampabile +- Mx5Italia (https://www.mx5italia.com/forum) +-- Forum: Tecnica (https://www.mx5italia.com/forum/forum-5.html) +--- Forum: Elettronica (https://www.mx5italia.com/forum/forum-25.html) +--- Discussione: [ND] Aggiornamento Mzd Connect / inserimento mods (/thread-30455.html) |
Aggiornamento Mzd Connect / inserimento mods - quantum - 14-02-2017 Questo andrebbe tra i problemi ... Dove sono elencati i link per scaricare l'upgrade alla 443c, ci sono due asterischi che rimandano al seguente testo: **[B]MZD Connect fails to establish Wi-Fi connection: [B]Only where Connected Services is used (Live Traffic Information, etc): For all with ADR or EU only and all Mazda Models up to about December 2015 Production. MMC has recognised that there is a hardware defect within cars CMU, basically the Wi-Fi and Bluetooth '[B]antennas' suffer from electromagnetic interference and causes a signal drop out as each antennae are poorly shielded. The fix is to renew the cars CMU with a modified unit, your Mazda Dealer may say that they will update Firmware first (cheap option), but this will not and does not fix the hardware issue, only replacing the expensive Connectivity Master Unit (CMU) will. You must complain to Dealer as they will not renew CMU unless you use the paid for subscribed 'Connected Services' feature..(this is not a Recall). Refer to MMC Japan TSB R006/16 of February 4th, 2016. [B]TSB .Pdf Here>>http://mazda3revolution.com/forums/a...1&d=1478590040[/B][/B][/B][/B] Aggiornamento Mzd Connect / inserimento mods - Diabolik R - 14-02-2017 Si ma si tratta di un problema hardware non software, una schermatura insufficiente fra le antenne WI-FI e Bluetooth. Sulla mia non ho avuto mai questo problema anche se in teoria dovrebbe essere fra quelle incriminate... ly:
Aggiornamento Mzd Connect / inserimento mods - quantum - 14-02-2017 Diabolik R Ha scritto:Si ma si tratta di un problema hardware non software, una schermatura insufficiente fra le antenne WI-FI e Bluetooth.Tu usi i servizi online? Domando, perché dal testo, pare che il problema riguardi quell'ambito. Aggiornamento Mzd Connect / inserimento mods - v3rsus - 14-02-2017 ...ora ci mancano le ansie da mazdaconnect... Aggiornamento Mzd Connect / inserimento mods - Diabolik R - 15-02-2017 Li ho usati solo nel periodo di prova gratuita. Aggiornamento Mzd Connect / inserimento mods - grayfox - 14-03-2017 Direi che ci siamo quasi https://www.cars.com/articles/mazda-to-add-android-auto-apple-carplay-capability-1420694439589/ Aggiornamento Mzd Connect / inserimento mods - v3rsus - 14-03-2017 Top...magari ci vorrà un anno...ma se confermano ê ok. Aggiornamento Mzd Connect / inserimento mods - quantum - 17-04-2017 Aggiornamento Mappe - vedo che sul sito non ci sono nuovi aggiornamenti gratuiti, quelli che avevo capito disponibili due volte all'anno nei primi tre anni, mentre a pagamento c'e' un aggiornamento piu' recente dell'ultimo gratuito datato 2015 Q4. Immagino ci sia solo da pazientare ma, a parte la confusione sui nomi degli aggiornamenti, qualcuno ha capito bene come funziona sta cosa? PS: tra l'altro, il costo dell'aggiornamento a pagamento mi pare cresciuto di parecchio rispetto a quel che ricordavo. Aggiornamento Mzd Connect / inserimento mods - CrazyCow - 18-04-2017 qualcuno potrebbe gentilmente mandarmi il link per " schermo che funziona anche in movimento col touch".. quello postato a me da errore. grazie Aggiornamento Mzd Connect / inserimento mods - Spal89 - 21-04-2017 Scaricate questo programma, contiene tutte le mod funzionanti con tanto di anteprime ecc... E molto completo http://mazdatweaks.com/ |
