[NA] Info Torsen
Mi sta arrivando un T2 da Uk, cosa devo controllare prima di montarlo sulla mia NA?
Di sicuro olio nuovo, ma vale la pena cambiare anche i paraolii? Dove li trovo?
grazie
NA 90 CV Montego Blu
Vendo ricambi/accessori
Hello mate,
you sure must change oil and I d suggest that you change both rubber gaskets to avoid leaks and also both bearings on top an bottome of the Torsen.
The gaskets are like 20 euros each.
The bearing are like 180 euros on Mazda, but you dont have to buy them from there. They are NK bearings, priced at 24 euros.
A.
nmwisima Ha scritto:They are NK bearings, priced at 24 euros.
A.
Great suggestion! Thumbup
Let me know if you can t find them to try and get the Part Number.
Thanks mate.
It would be useful to know bearing's sizes, therefore I could look for them into a standard bearings catalogue.
I guess I can find the gaskets on mx5parts or Il Motorsports, right?
nmwisima Ha scritto:Let me know if you can t find them to try and get the Part Number.
I need to know something about it, I too am going to install a Torsen.
I've looked on IL and MX5parts without find anything. I also looked on Mazdaonlineparts but drawings aren't clear (they are the same despite different car's year).
Any links here in Europe?
Is changing the bearings really necessary, btw?
Mine should be a low mileage diff, bearings should be still perfect...
Di solito è buona cosa cambiarli ad ogni smontaggio. Li ho cambiati su RC con 7k km...
Gaskets should be available from Mx5parts yes.
Bearings are ΝΤΝ 4Τ - 32008, they cost 30 euros for both.
Mazda charges 160 euros for both.
It is not mandatory to change no, but for 30 euros, its not worth NOT CHANGING, as if after the installation there is a noise or something, the labor costs needed to get the diff housing out again, would be 5 times more.Wink
I ve kept mine with no problem though, but if I knew the NTN price I would have changed them.
A.
Thanks mate, this info is worth more than 160€ Smile
  [NA/NB]  Paraolio pignone Torsen Alessandro 36 5,255 11-07-2023, 15:43
  [Vari] Valori tarature autobloccanti Oem VLSD-Torsen T1-T2-NC-ND Kublai 8 1,858 16-02-2023, 21:24
  [NB/NB FL] info differenziale gradient 2 1,313 09-12-2021, 14:47
  [NB FL] differenziale torsen mazdaspeed 182 67,418 18-11-2021, 16:05
  [NA/NB]  Revisione Torsen a Milano Pb81 1 908 09-10-2021, 17:42
  [NA/NB]  Torsen vs Retromarcia pierpower 3 1,384 25-05-2021, 09:34
  [NB FL] Olio differenziale torsen em98 2 2,413 22-04-2021, 09:36
  [NA] Mi date una mano per l'acquisto di un torsen? lsky 24 6,313 15-03-2021, 13:13
  [NB FL] Info cambio 5 marce falcon89 11 4,022 24-10-2020, 11:33
  [NB/NB FL] Non ci sono più i torsen di una volta Saimon 15 5,772 02-08-2020, 21:56
